I really do not find that my speakers are starved for power. Escpecially with movies. I can crank the living crap out of my system to the point my house is shaking with my speakers and subs rocking. I am wondering more from the musical point, I am curious about how much of a difference the amp will make. I only run a 5.1 system so I have 2 unused channels and I have never sent my reveiver into protection mode.
A more powerful amp will allow you to listen loud without worrying about clipping during the peaks that exist in just about any recordings (CD, DVD etc.). How severe those peaks are and how frequently they occur would depend on the particular recordings you listen to.
In terms of musicality you will not find consensus among people. You can buy a 20WX2 integrated class A amp that sells for $5,000 and may not find it any more musical than a 200WX2 amp that sells for $500. If you do a search you will find a full spectrum of opinions from one end to the other. The only way to find out is to try one out and hear it for yourself.
