copperhed
What makes or breaks a speaker is the crossover. It is equally, if not more, important than the drivers. I've heard DIY speakers made with cheap drivers, but had a carefully designed crossover, that sounded rather good. Many inexpensive, and some not inexpensive, commercial speakers suffer because the manufacturer skimped on crossover design.
That's why I (and others) couldn't believe that Micca sold speakers without any crossover. The capacitor in series with the tweeter, to keep the tweeter from rapid failure, doesn't quite qualify as a crossover. It is highly unlikely that two drivers will sound balanced, and make no unwanted distortion or noise, without some help from a crossover. At least you didn't pay much for them
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
A crossover circuit does more than provide low-pass filtering to the woofer and high-pass to the tweeter. It should evenly balance the sound across the all important mid-range where the crossover operates. And, it should equalize, as much as possible, any imbalances that come with the particular drivers and cabinet design. Beyond that, a really good crossover will allow a speaker to create a realistic spatial image that allows recorded music to sound more like real musicians and less like sound coming out of a small box.
To address your original question, a 2-way speaker with a woofer, tweeter, and crossover, really operates more like two separate drivers and not like two drivers in parallel. The low-pass filter keeps the woofer from operating above a certain frequency, and the high-pass filter keeps the tweeter from operating below it. If a crossover is at 2000 Hz, below 1000 Hz you hear only the woofer and above 4000 Hz you hear only the tweeter. At the crossover frequency ± an octave, roughly 1000 Hz to 4000 Hz, both speakers can operate at the same time, but at varying levels. At the crossover frequency of 2000 Hz, they will each make 50% of the sound. But they are not considered the same as two drivers in parallel.
The impedance of a speaker is never a simple constant value. It varies widely across the audio spectrum. It's measured by a full frequency sweep. The individual drivers, the crossover, and the cabinet design all affect the resulting frequency vs. impedance curve.
