seeking urgent pioneer assistance
and_woox
i have pionner d914 receiver and its cooler doesnt work at low volumes, only works around -27db.
and for this its getting kinda hot.
do you know if this is ok or not?
normal for receivers getting hot?
i have a proper setup.
thanks
rgriffin25
rgriffin25
Moderator
Should be fine. Most A/V receivers run a little hot. It will shut off if it is getting too hot.
K
korgoth
just make sure it has room on all sides and it will be fine most likely. most receivers run hot. some run really hot.
Spiffyfast
Spiffyfast
if your really worried hide a fan behind that blows air over the top
