Price: $1,499.00
The Samsung SPN4235 Plasma Flat Panel display reaches the highest level of performance. Drawing upon years of development and numerous picture enhancement technologies like exclusive DNie reproduces digital images with stunning clarity and realism.
Extremely powerful and quick, Samsung’s Plasma TV can handle the greatest challenges presented by digital and analog sources. With up to 852 x 480 resolution, they can handle the fine detail and rich color of computer graphics, as well as fast-moving video from DVD and HDTV sources.
Digital Natural Image engine by DNIe™
This first ever unique digital processing algorithm from Samsung, the DNIe™, realizes revolutionary life-like pictures through 2 enhancers and 2 optimizers - Motion Optimizer, Contrast Enhancer, Detail Enhancer, and Color Optimizer. This superior digital picture quality is clearly distinguished even in HD signal and works effectively with any display device type.
The Crystal-Clear Digital
Plasma TV is generated through total internal digital processing. When the TV turns on, the two address electrode panels cause gas to change to a plasma state and illuminate UV light. Then red, green, and blue phosphor filters absorb the UV light and re-radiate it as visible light. The self-illuminating system of Samsung Plasma TV delivers a crystal-clear and vivid image on a wide screen.
High Definition Image with WVGA resolution
Samsung’s plasma panels are both high definition TV and PC monitor ready. This allows the panel to be set up primarily for TV use, whilst at a flick of switch can transform it into a PC monitor for business application. Plasma with w-VGA resolution display realizes the truly picture-perfect screen quality of HDTV.
High Quality Picture on a Wide Screen
Plasma TV provides a high contrast ratio(1200:1) is designed to have remarkable brightness while consuming low power .With a high brightness and contrast ratio Samsung Plasma TV reproduces images as real as reality and eliminates screen reflections. For watching movies or videos with color-rich images, Samsung Plasma TV is the perfect choice.
TV Tuner Built-in
The Digital Natural Image engine, DNIe™
DCDi™ Faroudja Lab. Technology Process
Digital Ready TV (480i/480p/1080i)
Ultra-slim and lightweight
High Contrast (1200:1), High Brightness(700cd/m2)
16:9 Aspect Ratio
2 Tuner PIP & Double Screen
160 degree Wide Viewing Angle
720 line Progressive Scan
Dolby Virtual Surround
Cinema Progressive Scan
w-VGA PC Input (852 x 480)
DVI Input
Fanless for noise-free
Built-in Stand
Sub Woofer Output
