My earlier reply was misleading, and I want to apologize and straighten it out. My preamp (Adcom GTP-880) allows analog bass management on the multi-channel analog input (and I use it), so I
always get subwoofer output no matter what channels are provided by the source. (That is, in my DVD player, I set all my channels to LARGE, then the preamp redirects everything below 80 Hz from the front, center and surround channels to the subwoofer.) So, just because I could
hear subwoofer output on "Kind of Blue" doesn't mean it's coming from the LFE channel. On the other hand, as I mentioned before, the DVD player shows all six channels as active, so I'm pretty sure there's something on the LFE channel itself.
Beware, meanwhile, that anyone using any form of bass management will always hear subwoofer output, even if it has been redirected from other channels. My understanding is that your DVD player doesn't have bass management for SACD/DVD-A, so you're hearing it "straight," which is the purest test. For me to simulate your environment, I'd have to switch off my analog bass management, which means flipping a switch on the back of the preamp (difficult to get to). What we really need are three things:
1. Someone who owns the "Kind of Blue" SACD.
2. Someone who's using DVD-player-based digital bass management.
3. Then we need that person to set all the speakers to LARGE, play "Kind of Blue," and see what he or she hears.
'Course I could just flip that switch behind my preamp, and I might.
Rock&Roll Ninja said:
I though Hi-Res music had no LFE-track, but used the subwoofer only when applied with bass management?
No.
