Does anyone know how I would set this up to achieve less bump/thump from bass drums and more low end boom? I think that is how I would describe it. I used the set up guide from Rythmik under AVR since my Emotiva USP-1 has sub controls. My ML Grotto was set at 80hz and 180 phase.. Volume was at 75%. I was getting a nice LOW end with less short bass impact. For instance. With the sub off and playing just the Sierra 2's you wouldn't have much low end. Then cutting the sub on you would fill the room with deep lows instead of just bass drum attack with the ML Grotto... This is what I seek with the Ryhmik.
Sorry.. I am not educated much on subs.
You could also say I am looking at less attack and more low end resonating extension.
I think you have some misconceptions. First of all the lowest frequency of a drum kit is 50 Hz. So there are no deep lows to be reproduced. Drums do not boom, bad speakers do.
I have heard a lot of ML speakers, and the ones with cone bass drivers have all been glaringly bad in the lower end. It seems to me no one at ML has ever understood correct bass alignments.
So my guess is your reference axis is off and your Rhythmics are correct. There are sealed low Q subs. All ML speakers I have ever heard except the full electrostatics have the Q of the bass alignment far too high.
So if it is boom you want go back to your MLs, but it is not correct.
