Rxv-2500 Owners ---- Read This
bjc
I own the RXV-2400 so does anyone know if this is capable of fan control or trim?
Thanks Brett.
wadayaknow first post!!!
rkumaraguru
Does Yamaha RXV-2500 supports 220v Power input if you buy in US ?
Hi
I am newbie to this site.
Does rxv-2500 support universal voltage from 100 - 220V, if you buy in USA?
Can anybody help on this, if so where can i buy ?
Thanks
KUmar
crashguy said:
For those of you that are having difficulty with the loudness difference when switching input sources, try adjusting the "VOLUME TRIM" of your receiver. How to do this is described on page 53 of the manual in "advanced operation" section.
Did you also know that you can set the cooling fan to come on only when the unit gets hot - AUTO setting, or to run all the time at various speeds depending on internal temperature by setting it to the CONT. setting??
This can be done in the ADVANCED SET UP MENU described on page 81 of the manual.
Who knew you could learn so much by reading the manual....?!?!??!! :confused:
DR_AUDIO
rkumaraguru said:
Hi
Thanks
KUmar
No, only 120 or so. :(
