The Yamaha RX-Z9 is one of the most powerful receivers on the market and will have no problems driving moderately sensitive 4 ohm speaker. Take a look at our
power measurements for the RX-Z9 and you will see it is a true powerhouse as far as receivers go.
When determining if a speaker will be adequately driven by a receiver, you have to consider the following:
1) Speaker Impedance
2) Speaker Efficiency
3) Room Size and Liveliness
4) Listening preferences
5) Whether or not the speakers will be playing full range.
With that in mind, the Axiom M80's, despite their 4 ohm impedance, are a relatively easy load to drive due to their high efficiency and lack of sharp phase changes with frequency in the crossovers. You shouldn't have a problem with this setup.
