RX -V2700 and Surround Sound
twker
Ok, maybe its just late or it could be I'm a little slow I need some help connecting my speakers. Have the normal front right, left and center and rear right and left. Wiring is fine. With that configuration are the back speakers - Surround Back Speakers Right and Left or are they Surround Speakers Right and Left? What's the difference?
When I attempt to hook them up as Surround Back Speakers only the right one is found during the audio test. The manual has a note - "when you use a surround back speaker connect the speaker to the left Surround back terminal (single)" However, the diagram shows the speakers being connect to both terminals (left and right)
I do get audio when I connect them to the terminals labeled Surround Speakers Just not sure if its right.
Thanks
mike c
mike c
what the manual means is when you only have ONE surround back speaker ...
but you say you have 5 speakers, you should connect the surrounds to the "surrounds" and not the "surround back" (the speaker terminals right above the front left and right)
mike c
mike c
the surround backs are for 6.1 and 7.1 use. if you do have a 5.1 setup, use the "surrounds" speaker terminals
AVRat
AVRat
Pg. 15 of the manual lays it out pretty well, and pg. 16 of course are the connections.
