mnnc
I am adding a sub to my system which currently includes powered towers. The concerns I have are what would be the best way to connect sub and make settings on recv'r. I intend on using the single sub-out from recv'r then split into the l/r in on sub using a y splitter. I suppose setting bass-out on recv'r bass management to 'both' or 'sub' would send lfe's to both mains and sub or just the sub respectively, right? Yamaha recommends setting sub crossover to max and using the recvr's bass crossover management. Any recommendations would be greatly appreciated. Would it be fine to connect it as I explained and then play with recv'r setting to see which yields the best results? Thanks in advance.
