You should be fine using either optical or coax. There used to be a difference I could here between the two, coax being better. Nowadays, I can no longer hear any difference provided I use a decent quality optical cable. Optical also has other advantages, such as never oxidizing or corroding. It's really a coin toss, but you should come out fine either way.
