I am changing some things with my current speaker set up. And, I want to take this opportunity to do a little nicer looking installation of my surround and surround-back speakers.
I am using satellite type speakers and I have purchased wall mounts for each of my 4 surrounds. I would like to run my speaker wire through the crawl space above my ceiling. I am looking for a little advice on the best way to go about this.
We use the crawl space for seasonal storage, so i can't just run the wires loose through that area. I need to make sure they are bound or contained in some way.
I looked at some of the routing fixtures suggested in the "System Setup" forum. Unfortunately, I working on a budget and can't afford to spend several hundred dollars on routing the wires. I was thinking about buying some relatively small PVC and using that to contain the wires as they are routed from end of the room to the other. This would contain the wires and keep them from getting bumped by things we are storing.
Any reason why that wouldn't work? Are there safety issues I should be aware of with speaker wiring?
Thanks for the help,
Ross
