Rotel RA 1570 display dim problem.
Yohansen
Yohansen
Hello friends,
I recently purchased the Rotel RA 1570 amp from eBay, refurbished. Not a scratch and the sound quality is excellent. The seller gave me back $100, and I thank him for that.
If someone knows about electronics well, could you please tell me if the dim control on the display of the bar has 6-7 levels of brightness.
when I set it to only one level the brightness is at the minimum possible but some times it flickers very very slightly. I can live with that but do you think that later on will affect any circuitry somehow? It doesn’t bother me that it flicks very little, I just worry if it gets worse.
I contacted Rotel and the charge $75/hour, something that I can’t do because I’m unemployed.
I would really really appreciate your advice.
Thank you
