RG6 - Is this the right cable?
marklarry28
Hi guys,
I bought 20ft of RG6 double shielded. The specifications are:
Belden-T 9116R DUOBOND II 75 OHM SERIES 6 1C18
The cable is not that flexible.
Is this the right cable to make component cables? and also stereo audio cables??
Thanks
Mark
marklarry28 said:
Hi guys,
Thanks
Mark
If you can terminate them, it is the right cable for all your audio and video needs, except optical:D
Johnd
Yes, it is. Understand that there are literally dozens of different kinds of rg-6 available in bulk, some being more flexible than others.
markw
It'll work fine but it's overkill, IMNSHO. Whatever theoretical gains you might realize over using a thinner gauge, say 59U for example, are more than outweighed by the difficulties in working with the thicker cable.
Now, if you're taking about extremely long RF runs, than that's another story entirely.
danglerb
Can you use it, yes.
Would I, no.
Should you, honestly if you need to ask us if the cable is ok, then no.
Save yourself some grief and just blow $35 and buy a premade set of cables that you won't need to worry about for the life the system.
