I don't have everything set up to test right now, but I have an ultimax 15 in a denovo audio 3 cf. sealed box (3 pounds of stuffing). When running REW measurements, there's a big drop in the frequency response below about 28hz. When I select "match target response", everything levels out smoothly above the 28hz but it doesn't bring anything up, below that. I know REW does better with pulling the levels down, but doesn't do well with lifting up the levels. If I run the measurement after importing the settings to the minidsphd, the graph isn't smoothed out. Should it be?
Also, when I import the settings to the minidsphd, the graph doesn't look smooth within the minidsphd application. Should that be also?
