I
Ikeman
I'm not sure if this is the correct forum, but I was looking for some advice. I recently purchased an iTouch in order to watch movies while I live my life on planes. I have a few movies on DVD that I would like to put on the iTouch but I don't know which software would be good for doing the conversion. Any suggestions? If this is the incorrect forum, please let me know & I'll repost.
Thanks in advance.
Adam
Adam
Hey, Ikeman. The best software to use likely depends on which OS you are running (OS X or Windows).
Check out this thread from macrumors.com. It has some suggested software for both operating systems. If you are running OS X, I can try to find out what my brother uses.
EDIT: In addition to the programs listed in that linked thread, DVDFab is another option for Windows.
I
Ikeman
Thanks for your help Adam. For the record, I'm using Windows:(. Wish it were a MAC
I
Ikeman
Adam,
For what it's worth.
"DVDFab is another option for Windows."
I was having problems with the Handbrake software so I tried the DVDFab and the DVDFab works great.
Thanks again for the additional information.:D
