P Phouglas Audiophyte Sep 11, 2024 4 0 1 54 Sep 16, 2024 #1 I saw the pinned thread from a few years ago but curious where I should be ordering a replacement bulb from? There are a ton of options. Is there quality differences or should I be trying to order from Sony directly or some specific place? thanks!
TLS Guy Audioholic Jedi Oct 30, 2007 27,295 0 113 79 Eagan MN Sep 16, 2024 #2 Phouglas said: I saw the pinned thread from a few years ago but curious where I should be ordering a replacement bulb from? There are a ton of options. Is there quality differences or should I be trying to order from Sony directly or some specific place? thanks! Click to expand... Probably buy from Sony. Prices are all over the map, but I see quite a few 'sore heads' from buying cheaper ones.
BMXTRIX Audioholic Warlord Sep 16, 2004 8,803 0 113 Sep 17, 2024 #3 Sony or Pureland Supply would be my top two choices, in that order.
