Replacement cable recommendation-UE Triple-fi 10
L
Lewislink2
Hello and greetings.
Would like recommendations for replacement cables for my UE Triple-fi 10.
tyhjaarpa
tyhjaarpa
Why you would like to replace the cable? If you wish to "upgrade" the sound quality, don't waste your money as you wont get any upgrade to the sound it is just a marketing thing. If you have broken cable or need different lenght then just get cable that fits your phones.
L
Lewislink2
Mainly I just need a recommendation for a quality cable. Some might be better than others for durability etc. Thought maybe someone might know of a good alternative to the OEM cable.
afterlife2
afterlife2
I'd check eBay then check out a headphone forum like headfi.org. I have the UE 5's with the original durable cable and never had a cable problem.
mightymic
mightymic
Ya im looking for a replacement cable for my triplefi too. the default cable is pretty bad in terms of durability. it is so twisted that I cant get the cable straight. Let me know if you manage to find a good alternative.
