Remote Controlled Plasma Brackets
  • Thread starter Thread starter Vancouver
It's new to me, but it's not a bad idea.
I suppose a gear box installed between the fixed short arm and the long swivel arm with a DC motor inside controlled by an infrared receiver should do the trick, for horizontal movements of the plasma. Why don't you make one?
If I had the right contacts perhaps I would develop a prototype. Anyone here be interested in buying a product like this if it was made?
This application will probably be very useful in many smaller screen LCD TVs, let's say 12" 15" that are being widely used now by Hospitals.
I suppose for hospitals use you need to have a wired control that will swivel the screen up/down/left/right so patients can adjust it to a confortable viewing position.
I am sure there are many other applications including plasma TVs to be operated by an IR remote control.
Let's see, for this project you need:
1) a Gyro box to interface the swivel arm of the wall bracket with 2 DC controlled motors, one for vertical swiveling and the other for the horizontal.
2) an IR remote control receiver with a controlled relay with a quad action to control the left/right/up/down movements.
3) an IR remote control transmitter.
4) a specially designed wall bracket
