Remote control problems
K
kiran_sham
Hi,
My 1 year old Yamaha RXV1500 seems to give problems with the remote control. I was able to turn on the receiver with it but a few minutes later, it stopped working altogether since yesterday! It happened a couple of months back also, one morning, but somehow was ok by that evening, without me having to do anything.
Did anyone here have any such problems? I am not sure if this is a problem with the battery! How long do they usually last for? Had no complaints about the receiver except for this one now! :confused:
malvado78
malvado78
Try changing the battery and let us know. That is what it sounds like.
Jmoney715
Jmoney715
well the first thing i would try is changing the batteries, sometimes its just that obvious.... if not that then bang it a couples of times, always works for me :D
K
kiran_sham
Yes, I was planning to change the batteries this evening anyway!
The reason I am worried is because the display on it went off abruptly and not after gradual fading... Already tried banging it a few times.. :rolleyes: but that didn't help!
Will let you guys know once I change the batteries!
If you're using the batteries that came in the box, they are frequently old and not carrying much of a charge, and tend to die quick. Could be as simple as that. Worst case, it's a bad board/loose connection to the battery inside that might be easily fixed.
I had something similar happen last night with my TV remote. It just decided not to work for a few minutes, then it was OK ever since. I changed the batteries a few days ago when it seemed like they were dead.
K
kiran_sham
OK guys, I replaced the new batteries and everything is fine now! Appreciate your help!
Now that I changed the batteries, I observed that the volume doesn't change as fast as it used to do before. It decreases or increases like about 1 DB per second :eek:
