Recording audio from a hi-fi to a laptop
jpbl68
Can I use the microphone socket to connect to my hi-fi using a jack to split-jack cable? Not sure about the terminology, the cable I have has a headphone jack at one end and is divided into a red and black plug at the other (male & female, l & r). I was going to connect the split end to the back of my hi-fi and the headphone style jack to the microphone socket.
bandphan
bandphan
you need line level input, see if your you can change the mic input to line.
jpbl68
I've gone into 'Sounds and Audio Devices Properties', under the tab 'Audio' and heading 'Sound Recording' (which has a picture of a microphone by it) I have the option of chosing between 'Connecant AMC Audio' (currently selected) and 'Modem #1 Line Record' (it's an XP laptop). Is this what I need to select and will I need to download new software in order to record?
bandphan
bandphan
you will need software for recording. I use cooledit pro which is now adobe audition, soundforge is another. If line record means line level then the answer is yes.
CRIMSON PEARL
I was wandering the same thing. I need to transfere MD files to CD.:D
