Recommendations for speaker combos with Pioneer VSX 1120K
rmsarma
I am looking for suggestions on buying a good speaker set for the pioneer VSX1120K
JJMP50
Your receiver will work with just about any speaker systems on the market (8-6 ohm) so this is on you. Budget, taste and maybe WAF (stay away from small cubes). You have some work to do. If you haven't developed any pre conceived opinions or don't have access to showrooms, your probably safe with the major online guys (Aperion, Axiom..etc.). And spend some bucks on a sub!
ahblaza
ahblaza
hello, what's your room size, your preferences for media, music, movies and budget. This will help in your decision. Do you plan on a 5.1 setup or two channel, give some dimensions and uses for your system and recommendations will follow.
rmsarma
choices
my basement is 20 x 22 ft partially occupied by a laundry,
i have researched and lost with the options,looking to stay under 400 for SW, i have a PS3 and roku waiting to be connected once i get the VSX today
POLK PSW505 slightly older
Paradigm DSP-3400
SVS SB12
HSU research VTF-3 MK 2
Should i just opt for the LSi from POLK for Fronts, but don't want the floor standing unless they are cost effective.
I am undecided to go 2 / 5 channel but open to feedback on what i can squeeze out of the pioneer.
Will use it for movies and want to try the audio streaming via the sources
GranteedEV
GranteedEV
Forget polks... you can do better than that.
Go 2ch for now if it'll get you better speakers, but do get the matching center.
What is your price range for mains?
The HSU sub you listed is a nice one. What size room are you in?
rmsarma
want to stay within 500-800 range for the front and center combo, have approx 440 sqft basement for mains i am still debating between Kilpsch/Cervin Vega / JBL and matching center
sholling
sholling
$800 will get you a pair of b-stock Ascend Acoustics CMT-340SE bookshelves and matching center. Those are good easy to drive speakers.
440sqft assuming an 8' ceiling translates into roughly 3500cuft. I'd confirm this with Hsu but I think a VTF-3 will fill that space just fine and dig deep.
