<font color='#000000'>I need to get a new receiver and have done a little looking around, but am swamped with work. The problem is I need a AV switching capabilities and I have not found many systems that have the minimum req for my setup. I need a rec with at least 2 HD component inputs and two HD component outputs. I have found one, sunfire GTIII, but its very expensive and seems to have downfalls from your reviews. Are there other recs with 2 component outputs that you guys know about that I can check out? Thanks dgi</font>
