I am pretty sure that there isn't any bass frequencies being boosted up to 10 dB, because of the size of my room. It is at least 25 x 25 x 18 and open to the kitchen and entryway. If is also carpeted, has a lot of furniture and some fabric on the walls. Also, why it sounds correct with movies, but not music until I tweak LFE and sub level isn't explained by a room acoustics problem. I feel that I have my setup as good as it can be as far as level matching and would encourage someone to try to simulate what I have explained.
With my old setup...in a very small room I had the same issue. I had my levels matched and wouldn't get much output from my sub, so I just adjusted it with my ears during music, and figured it was an room acoustics issue. This was with a Denon reciever, and a separate subwoofer that I used to own. Now in a completely huge room I am experiencing the exact problem I had in my tiny room, so I am pretty much ruling out any resonance issues causing a bass boost. Another reason I rule out a bass boost, is that my speakers are 2.5ft. from the back wall, 2ft. to the left of my left speaker and ~10ft. to the right of my right speaker. Thank you for the help in trying to explain...but everything you are telling me is what I once believed, and I know exactly what you mean...but like I said, experimentation is how I came to this conclusion. If anyone wants to try this...I think I explained it pretty well in my second post, exactly what I experienced, so try what I tried and tell me what you think. If you have any questions feel free to ask and I will clarify. Again thank you for the replies, I won't stop at that though...I am convinced otherwise.
tbewick said:
I would recommend you use a test disc as, for some reason, test tones produced by the receiver sometimes give different results. This is what I've experienced.
Maybe this is exactly what I am experiencing.
tbewick said:
I'm a bit confused here. What I do is to leave the receiver volume for the sub on 0 dB all the time. I'd just adjust the sub's volume control for level matching. I could be being pedantic here, but the LFE volume will only be an option on DTS/Dolby Digital. Otherwise it will be called the subwoofer volume.
That is what I mean...The LFE adjustment on the reciever is separate from the Subwoofer level adjustment on the reciever...When I initially adjust the Subwoofer level on the reciever I have the LFE level on the reciever set to 0. When using the reciever's test tones to match the levels, I must adjust the Subwoofer level on the reciever to -10dB to get about 75dB on my sound level meter. If I were to watch a movie at this point, it is perfect. The problem is, if I listen to music (in a mode that the sub is utilized, which I hardly ever do) when it is setup like this, there is no audible bass (and I don't mean not much bass, I mean I can't hear any from the listening position), just midrange and treble. So what I do is boost the Subwoofer level on the reciever up to 0(10dB greater than when calibrated), and it matches the sound that my speakers make when given a direct "full range" signal without the use of the Subwoofer pre-out. If I leave it like this, then my movies are obviously going to have far too much bass, so I go into the reciever setup and decrease the LFE(used for Dolby Digital) by 10dB to compensate for the boost on the Subwoofer level. By the way, I don't use the level controls on the Subwoofer's themselves because they are separate, and it is much easier to just set them at an equal level, then use the reciever's level control to adjust it. Also, like I said in before, the Subwoofer in on my subs are set a the 2nd line past minimum, so I am assuming that if I set the reciever's level to 0dB, it would be much louder than 75dB, even with the levels on the subs themselves all the way down. I hope this is stated clearly, all the different levels and such could get confusing without reading carefully.
I don't like boomy bass, so I can tell you with confidence that there isn't way too much bass like you are thinking. I just took a Jazz class at my University and they have a treated room with Paradigm towers and I have compared the amount of bass in a Jazz recording there vs. my house, and I know that I don't have a huge peak at any of the lower frequencies. I can tell you, however, that when I listen to it with the lack of bass when the levels are matched for movies(without messing with the LFE like I did), that there is far less bass(like I said...not audible from the listening position) at my house than at the University.
I really appreciate your help...I don't underestimate your knowledge, but I would encourage you to experiment with this. Trust me when I say that everything that you have said has been my theory until now. I was convinced it was a room acoustics issue, but in my position, where I have fronts with an optional Sub in, I was able to do more accurate experimenting than with my previous setup.
