Receptacle surge suppressor with power conditioner plugged in?
crashkelly
crashkelly
Hi all,
Just wondering about a scenario.
For my HT space I have run two dedicated 20amp circuits to power all components. The one, as of right now, will only have my SVS sub and TV plugged into it so I purchased an in-wall receptacle surge suppressor to protect the two components. Now the other outlet/circuit will power everything else, digital cable box, AVR, HD-DVD, XBOX 360, CD changer, PS3 (eventually :D) via a Belkin PF60.
Is there any issue having the Belkin plugged into an in-wall receptacle surge suppressor?
I had to buy the one online as I could not find it in my area, other than the hospital/industrial grade ones that they wanted $150 for, so I bought two. My intention is that if I ever move I would have it to install on the other circuit when I take my Belkin with me, but if I can do it now with no issues I would rather do that than have to try to keep track of the package for who knows how long.
I am not trying to get any extra benefit out of this just don't want any detriment either
Thanks
Michael
Haoleb
Haoleb
Most manufacturers if not all, say not to daisychain surge protector type devices.
crashkelly
crashkelly
Thanks Haoleb.
I will just hide the second surge receptacle somewhere in the house that I will never forget and install a regular 20amp outlet for the PF60.
Michael
Rickster71
Rickster71
The only problem with "Daisy Chaining" refers to two or more power strips plugged into each other. People tend to overload them, forgetting they have 16 pieces of equipment plugged into one circuit.
Otherwise it's OK.
A typical surge-suppressor is comprised of a metal oxide varistor.(MOV) High voltage surges are clamped by the varistor to safer lower voltage levels. If you daisy chain your power strip surge protector, by plugging it into your suppressor receptacle, it's OK, you are just adding another MOV or two of protection.
Hopefully your receptacle surge device gives off an audible alarm upon failure. Some have a pilot light only, the problem with those is, they are usually hidden behind your equipment rack.
He is a little info on transients.
Most surges occur when devices with motors - hair dryers, refrigerators, water pumps - shut off. Suddenly the energy these devices were consuming is diverted elsewhere in the form of excess voltage. Surges also happen when the electric company switches power from one geographic area of the grid to another, as supply and demand in the region changes. Thunderstorms and lightening are the most dramatic and destructive causes of power line problems.
Only 40% of surge problems are generated outside the home or office by events such as lightening, utility grid switching, line slapping, etc. 60% of all electrical surges or transient voltage is generated within the home or office. Surges are caused by elevators, air conditioners, vending machines, copiers, large computers, even lights turning on and off will cause rushes of power and transient voltages back up the line.
Computerized appliances and electronics can be damaged or destroyed by over-voltage surges or spikes. This includes computer equipment and peripherals; electronic equipment such as stereos, TVs and VCRs; household appliances including washers, dryers, refrigerators, dishwashers, microwave ovens, food processors, blenders;(you get the idea):) and other electronic devices such as fax machines, telephones, and answering machines. Any electronic device that contains a microprocessor is susceptible to damage from transient voltages.
crashkelly
crashkelly
Thanks Rick. Got the PM as well and replied there.
Excellent information and I really have no worries about overload as the PF60 will be the only thing plugged into this circuit and then everything into the PF60. The other receptacle for the SVS Sub, man I love saying that :D, and TV is its own circuit.
Thanks again, your time and insight is much appreciated
Cheers
Michael
