Well, that'll be a real drag, because the Marantz receivers are, I believe, the smallest ones
(from the depth anyway).
Is it the height that might not fit?
* Can you use a saw and cut a small piece of your TV stand to make it fit?
* Or if you wait a few years, receivers will come in mini size with ICE power.
