Receiver help requested
G
gator_grabber
I have the following components and seriously need help selecting the proper receiver for my home surround system:
LP 47LC7DF TV, Sony BDP-BX1 Blu-Ray, BIC DV736 front speakers, BIC DV62CLRS center speaker, BIC DV53CLR surrounds and a BIC D1210R sub. I'll be adding 2 more speakers in the rear, but have not yet selected them.
I'm leaning towards a Pioneer VSX01TXH, but I'm really getting lost the more I search! I'd like to keep the cost below $700 if at all possible. Any advice please?? :D Thanks!
jliedeka
jliedeka
You obviously want something with HDMI inputs for the BD player. It would be good if it could decode all the current codecs. Beyond that, do you have a big room that you need a lot of power to fill? For a small room, any powered receiver would probably be fine. I would also consider future expansion.
In your situation I'd look for features and usability plus appropriate power. If the Pioneer meets all those criteria, you should do fine.
Jim
G
gator_grabber
The room is medium-sized, but I'm really not one to turn the power up. I'm looking for nice, crisp sound and useful functionality, not tons of 'features' that really don't add to the experience. I also tend to hang onto equipment for quite a while, so getting something that can be upgraded is a real consideration. Does it sound like the Pioneer VSX01TXH is worth considering?
jliedeka
jliedeka
It seems to have plenty of power and a reasonable feature set. If you are sure you won't need more than 3 HDMI inputs, then it should be as future proof as it can be. I'd say it's a reasonable choice based on the specs but I haven't read any reviews of it.
Jim
G
gator_grabber
3 HDMI inputs should hold me for a while. I appreciate the help. Thanks! :D
