SRHookEm said:
Thanks.
The Denon 3806 is actually the receiver that I am considering. I have some questions about it though:
I want to run my HDMI HD-DVD player, HD cable box and component DVD changer to the receiver and use one HDMI cable to the plasma. Does the receiver switch all inputs to HDMI? Are there any other HDMI issues with the 3806 I need to know--like handshaking?
If my wife wants to turn on the TV and use the built-in speakers, does the 3806 pass through HDMI when it's not on? Do any receivers? If not, how do you get sound to the TV? I would think that only cable would be used this way. All DVD's and CD's would use the receiver.
Any hints for using the 3806 would be appreciated.
There are times that I just want the TV on without the AVR being switched on. Here is the way I have my system set-up. I have an HDMI cable going from my DirecTV HD satellite receiver into one of my Sony's HDTV HDMI input ports and have an optical audio cable going from this receiver to my AVR-3806. This way, I can watch satellite TV without turning on the receiver (though my DirecTV receiver has to be set to PCM Audio out on the set-up menu instead of Dolby Digital output to get audio through the HDMI cable). I have the HDMI cable on my Denon-5910 DVD player also hooked directly to the Sony's 2nd HDMI input port. Hence, I can watch a DVD with sound coming out the TV speakers (though I have only played it in this mode a couple of times). I also have a Denon Link cable connected between the DVD player and the AVR-3806 for surround-sound audio (Dolby Digital, DTS, DVD-Audio, and SACD). Finally, I hooked an S-Video cable between the 3806 and the Sony TV to display the 3806 set-up menus on the TV. As such, I only have 3 cables going into the back of the AVR-3806 (Denon Link, optical, and S Video). I'm the type who would rather let the TV do the switching instead of the AVR (as described below).
When I first set my system up, I did pass the HDMI cables though the 3806. I don't recall any "handshaking" problems. I do remember however, that my 3806 had to be turned on before I saw any picture from the satellite receiver or the DVD player. That was the initial reason why I decided to run the HDMI cables directly to the TV. After having done that, I realized that I liked switching video input with the TV better than I did with the AVR. It's nice having the TV tell me that I'm using the "Satellite" input, or the "DVD" input, or the "Receiver" input, or the "Antenna" input.
Do other A/V receivers pass the HDMI signal when they are turned off? I don't have enough experience with other receivers with HDMI input/output to answer that question. However, I would wager that the answer is "no" to that question.
From what I remember from the 3806 manual (I'm presently not at home so I don't have my manual in hand), the 3806 will pass all video inputs to the HDMI output, but you do need to set up this option in the set-up menus (I'll give you the details once I get the chance when I'm home).
I hope this helps!
