I have a decent size room (17'x18') that I would like to setup a system for. The room has a pool table, dart board, things like that- so I'm not trying to setup a home theater, or stereo setup w/ a small listening area, this is more like a bar. It has speaker wiring already installed near the four upper corners of the room - including these four little sony cube speakers. I just bought 2 pairs of ELAC OW4.2's to replace the cube speakers (my friend has them for surrounds, they seemed like a good compromise in terms of size). I had planned on using an old 5.1 receiver I have lying around in the basement for a little while for at least one pair of speakers, but I didn't notice it has a minimum impedance of 8 Ohms (the ELACs are 6) until I dusted it off.
So my newbie question is this - what kind of receiver/amp should I get for this kind of application? I think I need:
- A few basic audio inputs
- Digital input capability would be good
- The ability to power the 2 pairs of 6 Ohm / 80Watt max speakers
- The ability to feed a powered subwoofer, just in case I am successful negotiating with my significant other
- Do NOT need any type of video processing
I figured I would look at "multi-zone" 2 channel amplifiers (w/ "A" and "B" speaker output),but what I am finding is that a lot of them have a minimum impedance of 8 Ohms when you use both "A" and "B" outputs, even if they have minimum of 4 Ohms for one pair of speakers. Should I wire two speakers in series, and use a amp rated for "12 Ohms"? Or should I be looking at a speaker switch with impedance handing?
Thanks in advance for any advice. This seems like a simple question, but I am having trouble finding much information outside of the home theater or stereo setups.
