Hi All,
This was stupidly posted in the wrong section yesterday, so I'm posting it again. Sorry if it seems like I'm repeating myself!
First, a little background . . . I'm using a Yamaha RX-V750 for a receiver, all Athena speakers, F2 fronts, B2 sides, C1 centres (front and rear) and SB400 subwoofer. I've also got a Kenwood RFU-R6100 hooked up to the centre rear channel to make it "wireless".
When I do the Yamaha YPAO, the fuzzy sounds coming out of all the speakers are roughly identical in volume (so I figure the problem ain't the RFU nor the speaker itself). And the results are:
Front Centre 10.0 feet +4.5 dB small
Front Left 9.5 feet +7.0 dB small
Front Right 9.5 feet +7.5 dB small
Surround Left 5.5 feet +6.0 dB small
Surround Right 5.5 feet +6.0 dB small
Rear Centre 8.5 feet +7.0 dB small
Subwoofer 12.0 feet -7.5 dB crossover: 120 Hz
Okay, all the info looks weird set up like that. The posting thingie wouldn't let me lay it out all pretty-like, so sorry, everyone!
The fronts are small?! They always seemed like tall suckers to me, but okay. I've noticed that the dialogue seemed a bit low, so I pumped up the front centre to about +8.5 dB. The crossover seems a bit high, and the Athena sub (freq. response of 23 Hz to 120 Hz) recommends a setting of just under 45 Hz if paired with the Athena F2 fronts (freq. response of 35 Hz to 20 KHz). Should I go with Athena's recommendation of just under 45 Hz? Or Yamaha's opinion of 120 Hz? Or the standard that most everybody seems to prefer of 80 Hz? I've been trying to detect the audio differences for the three crossover points, but I end up confusing the heck out of myself, not to mention giving myself a bit of a headache.
Now, even when I pump up the rear centre to +10.0 dB (the maximum it'll go), I can still hear barely anything coming out of that speaker, even though the fuzzy YPAO sounds are roughly identical in volume from each speaker. So I figure I need to decrease the volume coming to each of the other speakers. But to what? I tried reducing each of them (except the rear centre) by about 5 dB, and that seemed okay. But something was off. I think the fronts were just a bit too loud. Or was it the sides? Again, I was listening so intently and to so many variations that my brain finally turned off in protest. So what I'm asking is: If I decrease the fronts by x dB, should the decrease of the sides also be x dB, or should it be a bit more, or a bit less?
Or is there something else I should consider, instead of decreasing the levels of the other speakers?
If this post seems confusing, don't worry, it confuses me too. Any advice would be hugely appreciated. (Or if any of you wonderful A/V enthusiasts want to come up to Toronto to set up the levels for me, that'd be okay too!)
much thanks to all who can help, and cheers,
supervij
