Really confused and need clarification
hawee
Hi
Im my HT i have a Denon AVR-1908 receiver.
I'm new to all this stuff, can anyone help clarify.
What do the following do:
Speaker A
Speaker B
Theres a knob that lets me select different sound effects (DTS, 7 ch stereo, etc...) Which one do i select for the best surround sound or best sound??
hawee
i have a blu-ray plugged into the receiver with hdmi cord, will that give true surround sound? or do i need optical?
MDS
Speaker A and B allow you to select between two different sets of speakers connected to the front left and right speaker terminals. You could use that if say you had speakers in your main room and an additional set in the patio. The catch is that the two sets are wired in parallel and A+B (using both at the same time) puts a strain on the receiver. It's better to use the Zone 2 option to drive the second set of speakers.
There is no right answer to which of the various sound processing modes to use. Try each of them and see which you prefer.
HDMI will give you 'true surround' if it is configured properly.
hawee
in our ht we have
3 front speakers
2 side speakers, left one and right one
1 back speaker
when i watch movies the receiver tells me its on DTS
does that mean its giving me surround sound?
also i never hear anything from the back speaker when im watching a movie but i do when i turn it onto tuner
MDS
The receiver will only indicate DTS if that is the format of the source it is receiving. DTS must be manually selected from the DVD menu because Dolby Digital is the default, but yes DTS is a surround format.
The use of the surrounds varies from soundtrack to soundtrack so sometimes it is very pronounced and sometimes it seems like there isn't much info in the surrounds. That is normal.
The tuner (radio) is 2 channel stereo so if you are getting a lot of sound from the surround speakers in tuner mode, then your receiver is set to use a matrix decoder that turns 2 channel into surround. It may default to a particular decoder, but you should be able to change it, if you desire.
Midcow2
Midcow2
Your AVR supports HDMI 1.3a
You can obtain audio and surround sound from you HDMI cable. True surrouind ? You can set different surround modes on your 1908: Dolby Digital Surround EX Decoding, Dolby Pro Logic II,Neo:6 Stereo-to-Surround Cinema, dts ES Discrete, dts ES Matrix
other surround modes on the Denon AV-1908:
Mono Movie Surround Mode
Rock Arena Surround Mode
Matrix Surround Mode
Jazz Club Surround Mode
Virtual Surround Mode – For 2 Speakers/Headphones
Multi-Channel Stereo Mode 5/6/7
DSP Effect Modes 7
Auto Surround Mode (Analog or Digital Input Type)
Active Center Channel In All Surround Modes
It is really up to you and what sounds good to you :rolleyes:
hawee
it only allows for me to select DTS and others Dolby Digital isnt an option
Halon451
Halon451
Dolby Digital certainly is an option on that receiver, you're just having difficulty getting there. Might I suggest sitting down with your user's manual and reading it over thoroughly to understand how to navigate the menu. :)
Midcow2
Midcow2
Okay maybe I am wrong I got my info from an online manual
Hi
Detailed specifications of AVR-1908
http://usa.denon.com/ProductDetails/3635.asp
SOUND MODES
Dolby Pro Logic IIx – with Cinema, Music, Game Modes
dts ES Discrete 6.1 Decoding
dts ES Matrix 6.1 Decoding
dts Neo:6 Stereo-to-Surround Cinema and Music Modes
dts 96/24 5.1 for DVD-Video Processing
Audio Signal Delay (Sync. Audio with Video signal) – By source
Stereo/Direct Modes w/Pure Analog Path
Video Game Mode
DSP Effect Modes 7
Dynamic Discrete Surround Circuit - Digital HD Dynamic Discrete Surround Circuit - Digital HD
From your manual pages 34-35
http://usa.denon.com/AVR-1908-OM-E_109.pdf
To select these surroound modes using the buttons on the main remote control unit press the STD button. The mode switches each time the button is pressed
Almost all of the surround options are under DSP Simulation playback:
"The surround paramters can be adjusted (page 59, 60) to achieve an even more realistic, powerful sound field"
MDS
DTS is not an option you can select manually nor is Dolby Digital. If that is the format the receiver is being sent, it will automatically switch to the DTS or DD decoder. The only way to 'select' DTS is by choosing it from the DVD menu.
You may be confusing DTS with DTS Neo:6. If you can select Neo:6 then the receiver is getting a 2 channel PCM signal. If so, the reason is either the DVD player set to PCM when it should be set to Bitstream or the digital input format on the receiver is not set to Auto.
