The x-max, I have read, is rather overstated on the RE Audio drivers.
The Audiopulse units for example, are conservative on x-max ratings. Take the AXIS for example, it is rated like 30mm one way, but it's mechanical limits (x-mech) are far greater. The x-max is the linear motor rating limit on the AXIS.
The RE Audio are good drivers, but I would not take them over Audiopulse unless of course you found an incredible bargain/deal. To my knowledge, the proven highest quality 18" in the world is still the TC Sounds LMS/Audio Pulse LMS Ultra.
In reality, the x-max is far more than you can use in most cases. Take the AXIS with 30mm one way. With 2000 watts RMS, you can only use about 1/2 of that (15mm) range in a sealed cabinet with a reasonable QTC of say 0.8 to 0.7. In a ported unit, the excursion is reduced further. I can't imagine under what conditions that 54mm is need on an 18" driver, except for simple SPL limit competition using 10,000 watts of power or something....
-Chris
