RCA to XLR cables suggestions for Marantz Cinema 40 to Buckeye Amps module Hypex NC502MP
Have ordered XLR to XLR cables from both SVS and Blue Jeans. Happy with both cables and they’re under $100. Both will make whatever connector ends you need in the length you need. Good luck.
Do yourself a favor and go to a music store- buy some Hosa cables and compare them to the others. It's doubtful that you'll hear a difference if you don't know they're being changed or left alone. If you know, it's hard to be unbiased.
Bobby Bass
Bobby Bass
Just checked out the Hosa cables on Amazon. Good ratings and cheap. I’ve had mixed experiences ordering cables from Amazon but as a Prime member it’s usually risk free and worth a try. Have tried Worlds Best Cable, GearIT and Cable Matters. Will check out Hosa next time I need cables.
