G
gumbeelee
i would just like to know what brand of rca cables do you all suggest to run from my alpine head uniit to my amp. i have a five channel amp and i am going to run all new rca cables. the main reason i am having to run all new rca cables is i am having interference through my speakers with the rca cables i have right nowl. i am getting the ever so common whine noice through my speakers. i was just wondering which brand and exactly which rca cables are the best for eliminating the whine and which rca cables are the top of the line? thanks alot :D
thank you
gumbeelee
G
gqmagic
You have any component cables use those. I didn't know a "whine" was common.
thank you
gumbeelee
We may have a car audio thread or folder in another area but your RCA cables aren't the cause of the whine. You have a ground loop. The cheap way to eliminate it is by using a ground loop isolator but that usually screws up the sound quality. The correct way is by grounding the equipment properly and setting the sensitivity controls on the amp(s) correctly.
