Questions about 3.5mm (1/8") connectors and stereo/mono conversion.
KEW
KEW
I have two discreet questions:
1) What is the most economical way to buy decent 12 volt trigger cables. From what I see, the mono ones are in rare supply, but you can buy a stereo cable for next to nothing. Can I use a stereo cable with 12V DC Trigger?
Suggestions for buying a couple of these inexpensively? Many places, the cost of shipping is a deal killer.
2) I bought JBL Peebles when they were on sale for $20.
http://www.jbl.com/computer-speakers/JBL+PEBBLES.html
They have very good sound for USB powered speakers. I generally use these with a tablet headphone-out and use a USB wall socket for power. My problem is, the two speakers can be a pain if I want to grab and go.
What I would like to sometimes do is leave the second speaker behind. My concern is that I would be only getting the content from one channel. I am wondering if there is a convenient way to get a summed R+L mono signal to the single speaker, say like plugging a mono cable into the headphone jack. Does anyone know the signal assignments of the sections of the pin?
KEW
KEW
Thanks, I think I smoked too much crack last night (or something)!
Seriously, I must have had a typo in my search, because you are right!
rojo
rojo
12-foot
25-foot
Or if you need longer, you could always just get a short 3.5mm TS cable, cut it in the middle, strip the jacket, and splice in some speaker wire. I did something similar with some old hoarded HTIB speaker wire to run a remote turn on wire from my AVR at the front of the room to my Niles AC-3 behind the seats. A bit of heat shrink tubing is a good idea if you do this though.
KEW
KEW
Eh, I'll just use the stereo to mono adapter. Needing to carry an extra component would completely defeat my intended purpose, and the cost of the solution is greater than my $20 cost of the powered speakers.
If I was doing it with my real system then I would be interested in reading/understanding it and getting the gear to do it right.
