Question on starting a music system?
E
excetara2
I want to basically put a two channel system together now for music. Eventually I may use the amp for a 5.1/7.1. I was planning on either getting the Outlaw 950 or Rotel-985 pre/pro. I want something that has bass management fucntions. I like the fact that you can output the sub channel with the speakers in full mode also. I was planning on getting a 5 channel amp. Using 2 of the channels for now to power the fronts. Then using a third channel to power a sub. This would work fine correct. Electrically I know it would. This would work ok with the sub powered with the same amp as the fronts. Does anyone know of some good plan stereo pre/pros? I could go for that. i just didn'y know of any. I want a subwoofer output. I could get one without bass management fucntions but then does anyone know of a good crossover for just a sub. Any advice or expertise will help. thanks a lot.
If you want to do stereo ONLY, I'd go with the Outlaw RR2150, the only problem is they are currently out of stock. It has bass management and a sub pre-out.
While it would work to use the power of one of the other channels to drive a sub, this is not the best plan becasue a sub will draw more current than anything else. A powered sub would solve that.
The13thGryphon
The13thGryphon
Yes, you could power a sub with one channel of a multi-channel amp. However, most of today's subwoofers have a built-in amp to power the sub, so that wouldn't be necessary in most cases.
Also, most recent sub's also have a crossover built in as well. If you get a powered sub with both a speaker level and LFE (low frequency effects) then you'd have a very flexible sub that could work well in both a stereo or theater system; and would also allow for a variety of connection options. I.E., using the speaker level inputs (and crossover) for music, and the low-level input from the LFE or "sub" output of the receiver or pre/pro for movies.
I'm not aware of any stereo pre/pro's. Those that I am aware of are multi-channel units designed for 5.1, 6.1, 7.1, and in some rare cases even more channels.
There are many ways to start off with a relatively simple 2-channel system and grow into a full surround system. Here's a couple of examples: 1) you could purchase a decent receiver from Denon, Marantz, Yamaha, Arcam, etc. to begin with, and then add a 2-channel outboard amp for the main left and right speakers to add more dynamic impact, clarity and "grunt", and finally add a 5-channel amp later for a full 7.1 system; or 2) you could also get a pre/pro such as the Outlaw 990, B&K Reference 50, or Parasound 7100 and a 2-channel amp now, and then add a 5-channel amp and additional speakers in the future. In either case you could hook up the sub and use it now along with the stereo output, and later with the full surround setup.
