Mike,
There are tons of options for whole house audio - and some questions to be answered.
1. Do you want to keep it as simple as possible?
If so, then that would be speakers in each room and volume control back at the head end (mechanical room) with an impedence matching/volume control speaker selector. I haven't looked into these at all.
2. Do you want local volume control?
If so, then you have a speaker selector back at the head end, the speaker wires come out of that and run to volume controls located in each room, then they go up to the speakers in the ceiling. This is likely the most common way of doing things. If you only want to play one source, like a CD player, you can hook it up to a good (powerful) 2-channel amp, then to the speaker selector. Very simple, and it works well...
3. But, if you don't want to go down to the head end every time you want to start your music, and you want indivdual room control you might consider investing in some IR repeaters that go into the volume controls. That way, you can control the CD player (etc.) from the room you are in. IR repeaters are nifty - but you will be carrying a remote into every room - and losing it all over the place.
4. How about stepping it up to include advanced room controls? Ground up designed distributed audio systems use CAT-5 at each wall station to not only provide volume control, but allow for multiple source selection and for IR control of that source in each room.
www.sonance.com as well as a bunch of others makes whole house systems that are very good. Typically you need a multi-channel amp - one pair of channels for each room, and the controls. For 9 rooms, you would need 18 channels of amplification which is 2 12-channel amps. Giving you some room to spare. This is very cool, but not the best still.
5. If you want ultimate room control you can go with AMX/Crestron control systems. I'm a Crestron guy so I will talk about that...
You have the similar pre-amp - up to 8 sources - at the head end, from there into an amplfier (1 channel for each speaker - same as above). Then from there directly to each speaker. Each room is controlled from a large variety of keypads, in-wall touchpanels, wireless touchpanels, or via Ethernet. It allows for XM radio and for you to know what station is currently playing. Setup playlists on digital jukeboxes, and for you to pick and choose your current FM station with ease. Almost anything you dream of can be done... But, it is expensive, and programming is done by professionals usually. At least, that's why I have a job.
What is best for you? Well, probably the second option - volume controls in the walls and speakers in the ceiling with a speaker selector at the head end.
Speaker selectors just have a row of buttons on them that let you turn individual rooms speakers on and off.
Volume control example:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=20709&item=4387458492&rd=1
Speaker selector example:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3279&item=5780594743&rd=1
Is anyone aware of a 9 room speaker selector?
