Ok so a month ago I bought one of the $100 Insignia Home Theatre Systems (200 Watts). I now want to upgrade but piece by piece since my pockets are a little dry. My question to you professionals are:
1) I want to start by upgrading my floor speakers to some that are 150 watts per channel. Will my Insignia Receiver that came with the Home Theatre System be able to handle those speakers?
2) If it does not then how big of a receiver is needed to house the upgraded speakers? Basically does the receiver ADD sound to the speakers/system or is the Watt # given the amount of watts it can handle?
3) How big of a difference is the HD sound? I currently own a 42" Panny Plasma.
Thanks for your help!
Hate to say this but my first recommendation is to go return that whole Insignia package and start from scratch again.
Now on to the other questions:
1. Speaker wattage means nothing so don't go by that at all. You first pick out the speakers you want and then choose the electronics that go along with it accordingly.
2. Just because a speaker is rated at 150w doesn't mean that you can put more or less power to them. All receiver does it take the signal that is sent to it by the cd/dvd/bd/hd dvd player and play it through the speakers. Of course when you get into surround sound formats like DD, DTS, TrueHD, DTS-HD, DD+ it gets a little bit more complex but that is the gist of it.
3. If your pockets are king of dry then I wouldn't worry about HD sound from a BD or HD DVD as that can get quite expensive. You are getting into a hobby that can become super expensive very fast so it's best to take your time and figure out what you want first and take it from there.
So now it comes down to what is your initial budget and what do you want to accomplish. If you want a full 5.1 HT setup with high def like BD or HD DVD but don't have the money to pay for it all up front you are going to have to do it in steps. First thing you should start with is a pair of front speakers and a receiver. If you want to eventually have a 5.1 system with BD or HD DVD you should get a receiver that can handle all the HD stuff off the bat.
So first let us know your initial budget for 2 speakers and a receiver and we can go from there.
