Question about Restoring a Computer
Squishman
Squishman
I want a 32GB and I do not have $1200-$1500 to spend. So, no. I am not returning it.
Cos
Cos
Just a note if you reinstall the OS on your old laptop, you can still update it to windows 11, my point was the software that came in the firmware or USB is most likely Windows 10.
  • You can go with third party windows key sellers. I have used this on multiple builds. I found it on guru3d.com, it's like 15-20 US.
  • You need to be careful though and check the seller feedback and return policies. I have used in 4 times w/o issue
  • You do NOT need to worry about viruses being installed, because you go to Microsoft and download the windows 11 Software.
Squishman
Squishman
Ok thx. It's not a laptop. ha.
dolynick
But still when I restore it, it will either revert back to W10 or 11. I guess no one knows what to expect here?
But I will shut it down at the first thing you see, which is to select your language. The new owner will set it up and log in with his own credentials.
This will depend on exactly what process you use.
There is the original laptop/desktop maker's factory restore, which would reinstall the original OS.
But there is also a simple Windows reset, which will essentially just reset/reinstall the current OS.
Both (or at least the Windows reset) will ask if you want to keep your files or not. Be aware that this is just a simple delete and not a secure erase. With a simple delete, the space is just marked as empty but the data is still there if you use the correct tools to inspect the drive space. This is what some of the others are referring to when advising to destroy the drive or use a secure erase program. I would expect that the secure erase program may well destroy the ability to reset or factory restore on the drive anyways though.
As for if Lenovo is any good... Depends on the model. Every brand makes some better models and some cheaper crappier ones. My family bought some very nice Lenovo laptops a few years back. No real complaint there. These were their higher end Legion series though and in a different price bracket. My opinion is that if you're shopping the lower end models, they're all going to be compromised in one way(s) or another. Doesn't really matter which brand. The question is if the compromises are a deal breaker for your use case or not.
If you like the features and specs of the Lenovo you picked up, and you're not finding it crippled with excessive adware and bloat, I'd say just stick with it.
Squishman
Squishman
I just looked at the Legion out of curiosity. 8.3" wide. One criteria I was looking for was a slimmer width. The Lenovo I ordered is 3.5", which is perfect. And the Legion says it is "gaming". Certainly beyond what I need. I got the right one for my purposes.
As far as adware and bloatware, I imagine that crap is all uninstallable.
Squishman
Squishman
Price was reduced from $950 to $799. Not too shabby.
Verdinut
Verdinut
A couple of years ago, I bought a used Lenovo T530 ThinkPad. So far, it has been functioning without any problem.
I was bugged quite awhile by Microsoft about upgrading to windows 11. I refused to upgrade every time I was receiving messages. Recently, they informed me that this laptop didn't have adequate hardware to switch to Windows 11. I know that with the Windows 11 OS, you will be spied on, and this is the reason why I don't want anything to do with Windows 11.
On my desktop, I'm using the free open source Ubuntu 24.04 Pro with a 10 year support. It is a Linux distribution OS, and It takes a little period of time to get acquainted with it, the commands are more complicated for instance. It's a very stable OS with frequent protection updates. Overall, I like it and I will eventually abandon the Windows 10 OS on the Lenovo and replace it with the Ubuntu product, which has not been subjected to malware to date. Also, with an open source product, the risk of being spied on is IMO unlikely.
I had Lenovo, three laptops ago, and it was fine, but they have gone way down hill since then.
Squishman
Squishman
What do you guys suggest about anti virus and/or malware protection? Right now I have only Malwarebytes that I pay around $30 yearly. The new computer comes with a one year subscription to McAfee Total Protection. What do you recommend? Stick with Malwarebytes? Go with the McAfee? Both? Something else? Go with McAfee for the free year, then something else in a year?
Squishman
Squishman
I just watched a couple of videos on anti virus programs. He said Windows Defender is in the very good column as is Malwarebytes. He had McAfee in the absolutely avoid column along with Norton. They were the two worst.
Windows Defender is free iirc. So I'll just make sure I have that. I wonder if it's ok to run two? Any comments on that? So I will uninstall McAfee from the get-go. I think I have 10 months left on the current Malwarebytes subscription. He didn't recommend any of the free ones that used to be good like AVG, AntiVir, etc.
Verdinut
Verdinut
IMO, Malwarebytes Premium is actually the best anti malware/virus available. I have been using this software almost since the beginning of their operations in around 2004. I'm one of the lucky ones, because of my long time use of their product, having a lifetime free subscription.
I strongly recommend that you keep Malwarebytes but keep subscribing to their premium protection which operates constantly when your computer is operating. If you reach a suspicious site, Malwarebytes Premium warns you and recommends going back. You won't regret it.
Squishman
Squishman
Thanks. I missed that lifetime subscription. I have had it for years. Cannot recall how many, but it was scant weeks after they ended that. As Maxwell Smart would say "missed it by that much".
Eppie
Eppie
The OS is typically partitioned or on a second drive. I've used this company"s software for transferring data and programs from one PC to another for about 12 years
EaseUS
Does EaseUS transfer most programs ok? Windows baked in utilities only transfer documents and some settings but not apps. I'm transferring my wife's setup to a newer laptop and was looking at Laplink. Are you using ToDo PCtrans?
everettT
everettT
Yes, that is what I'm using and it does transfer apps.
Squishman
Squishman
The Lenovo desktop I bought a couple days ago is now $949. I paid $799. It'll be interesting to check on Black Friday what the price might be.
It arrives today, which is pretty cool.
budjo
IMHO the best way to get a good computer is build it yourself. It’s easy to do and you get exactly what you want. Plus you have the satisfaction of you building the computer. Then you can upgrade in the future without a large outlay. YouTube has lots of tutorials.
everettT
everettT
I agree about building one's own, but it's definitely not rocket science. Being patient is the only requirement IMHO.
Squishman
Squishman
I got the new one set up. Very slick unit! I was pleasantly surprised to find very little crap on it to uninstall. Except McAfee, which I uninstalled and put Malwarebytes Premium on it instead.
Squishman
Squishman
Just out of curiosity, I looked at Windows 11 desktops on Bookface Marketplace. There are many, many of them listed. There are also some with Windows 10. Prices are mostly around $75 to $100. Not even worth the effort, if I was to restore it, possibly get a new HDD, etc. In the closet it goes!
Squishman
Squishman
I will eventually add a DVD drive for the (very) occasional ripping to my iTunes library or burning a CD for a friend. It would have been nice if there was at least a blank slot on the front. So It'll have to be external.
