Question About Phantom Center for Home Theater
JohnnyN
I can't find the answer to this question anywhere. When implementing a phantom center, what happens to the information that would normally be sent to the L/R channels? Are the L/R channels able to play the center channel audio + the L/R channel audio simultaneously? Or is the info that would normally be sent to the L/R channels lost when you're relying on them to play the center channel audio?
(I hope I'm explaining my question clearly. I understand that the information that would normally be routed to the center channel is instead routed to the L/R channels and the desired outcome is a phantom center. My question is about the information that would normally be routed to the L/R channels, when the L/R channels are being used to play the center channel info in phantom center set-up.)
The downmix I'd assume would put the center content into the L/R channels....but not sure how that particularly works in each avr out there....
The left right information is not altered. The center channel is sent to the left and right speakers 50/50 and so you get a mono center image.
Most centers are so poor, that if you have good left and right speakers, you are better off with a phantom center, unless you have a really good center and they are far and few between.
TheWarrior
TheWarrior
Precedence Effect
That is the name for the phenomenon that allows you to perceive two separate sound sources, like a L + R speakers, as one image.
'Phantom Center's' exist due to this. But it is a less desirable set up than having an actual center channel speaker. Center speakers are arguably the most important in any surround sound system, simply because the majority of sounds are directed to the center channel.
lsiberian
lsiberian
I had a phantom center for a while. I too preferred it to a low quality center speaker.
bimasta
I only use a phantom center. That's the purpose of Stereo: listen to any classical concerto (violin or piano) through a normal 2-channel system, and the solo instrument will be center-stage, where it belongs.
The same thing happens with the L/R fronts in an HT setup — the dialogue will "seem" to be in the center, and sounds more realistic.
A phantom center eliminates the need for a center-speaker (saves money) and frees up an extra mono channel on your amp.
