Question about Center EQ setting on my Yamaha receiver
cnjax
Hi I have a Yamaha RX-V1000 and there is an option for the center eq can anyone tell me how to set these?
Thanks
ParadigmDawg
ParadigmDawg
to off...
I have tried the auto eq for the center and the manual eq for the center and mine sounds best "off".
Thanks
cnjax
Thanks for the reply, unlike you I do not have an auto setting for the center channel. Just a slider for several frequencies, it reminds me of an old equalizer.
jcPanny
jcPanny
Yamaha EQ
The center channel EQ is intended to help compenstate for a center speaker that does not match the main L/R channels. If your front speakers match, don't worry about the EQ.
