Question about bi-wire and bi-amp
MDS said:
I would love to hear how a speaker wire can 'separate the highs from the lows'.
Interesting, me too:D Many years ago Monster said the same thing about their wires with different gauged strands, LOL, that the thin will pass the high frequency and the thick ones the low frequency. Someone suggested to a Monster sales guy to grab the thin wires plugged into the 120 V outlet and test his theory :D
DDigitalguy06 said:
The bass will be lot tighter and it wont sound so boomy.!
Maybe you can explain this? Curious minds want to know how and why this is.
mulester7
mulester7
......two elements are being paralleled, and they have seperate crossovers that apply only to them even if the two crossovers are on the same board with a single attachment.....they got to have seperate crossovers if you can bi-amp them, now think fire....and they GOT to have crossovers, if you run both top and bottom in any configuration, or they would be totally offensive after the point they should have been crossed.....the top and bottom have their own crossovers, would have to....and you can parallel that....one advantage of bi-amping might be make the top or bottom stronger or weaker....you can bi-wire them and do that with an L-pad mounted on the enclosure.....I'd go for 4 ohms, and have somebody pass me that platter of fresh watts.....
Ahm, sorry, this doesn't explain my question to his claims.
There are two crossovers, or more, even when not buy-wired. Irrelevant issue.
mulester7
mulester7
....I just picked your post to pop, Mtry....settle down and climb out that hole....(four).....
mulester7
mulester7
DDigitalguy06 said:
He will here a difference when he bi_wire he speakers!
The bass will be lot tighter and it wont sound so boomy. it will seperate from the highs. and it will sound alot cleaner!
.....this is what DDigitalGuy said, and you start right in, Mtry....he said changing the speaker to 4 ohms brought cleanness and life to it....Mtry, can ya' hear me down there?....huh?....(five)......
HUH???
I know what he said and I asked about this from his post, to explain further. Perhaps he has an clear explanation about it, how and why? If not, then it is a guess perhaps. I like good, solid answers I can take to the bank.
mulester7
mulester7
mtrycrafts said:
HUH???
.....how can an ears-issue be taken to the bank?....he obviously is not a village idiot....he posted what he heard....would blindfolds change what he heard?....the bass was cleaner is the reason.....
brian32672
brian32672
mulester7 said:
.....how can an ears-issue be taken to the bank?....he obviously is not a village idiot....he posted what he heard....would blindfolds change what he heard?......
You both realize that between you both this is otiose.:rolleyes:
Buckle-meister
Hey Mulester7, Mtrycrafts told me you kicked him in the shins and poked him in the eye just for, well, just for fun! :eek: Any truth to that? :D
Regards
mulester7
mulester7
....go fix your blown-out windows, haha.....you made me go to dictionary.com on otiose.....
mulester7
mulester7
Regards
.....that would be the Gospel Truth, you ole' bagpipes totin'-plaid skirt wearer.....
brian32672
brian32672
Hmm, how obtuse of you.....:p
Regards
Funny, LOL. If he agrees to it, I will attest to it. J/K:p
So, in the end, he cannot shed more light on the issue of buy-wiring, other than what he thinks he perceived. For a moment, I thought there was a breakthrough in the science of buy-wiring. No, there is nothing to take to the bank, as my psychic ability foretold. So, you see, I am a psychic.
mulester7
mulester7
mtrycrafts said:
So, in the end, he cannot shed more light on the issue of bi-wiring, other than what he thinks he perceived. For a moment, I thought there was a breakthrough in the science of bi-wiring. No, there is nothing to take to the bank, as my psychic ability foretold. So, you see, I am a psychic.
.....Mtry, keep your day job, and what he did, was take a 2-way "8 ohm" full-range speaker, and change it to a 2-way "4 ohm" full-range speaker....the amp section pushing the speaker is now firing 4 ohm bullets.....
Not if he buy-wired them with the same amps he didn't.
By the way, how do you know the speaker became 4 ohms? Did someone use an impedance bridge and swept the frequency range to arrive at the impedance, checked some published impedance measurements of the speaker, or just a DC resistance measurement? Not the same.
brian32672
brian32672
mtrycrafts said:
In that case, he did.:D
Glad to know, that you know, I was joking........:)
No big deal Marty, but I was wondering why you keep using BUY instead of BI.
You have used it at least 10 times.:confused:
Bi-wiring, Buy-wiring:confused: :confused:
Unless, you mean he is Buying to much wire.:p
That's easy. One buys the extra wire to bi-wire the system but it has no beneficial effect, hence, it is just a buy more wire thing:D Makes the wire companies richer a bit. Like Monster would need to be richer.
MDS
So what? Is that supposed to be a good thing? Going from 8 ohms to 4 ohms makes the load harder to drive. The receiver now has to deliver twice as much current and twice as much power. It won't be any louder and it doesn't affect sound quality in any way. 100 watts into 8 ohms = 200 watts into 4 ohms = the same SPL.
