PSB SP-25i speaker stand
skads_187
skads_187
Does anyone know the height of the PSB SP-25i speaker stands?
I gonna be using the b15's as the 2 back speakers. However, a lot of stands I have noticed are not that tall, they go about 2.5 ft. in height, then plus the speaker on top of it. Im wondering if these will be too low. I know they say that the back speakers should be about 2-3 feet higher than your ears.
E
Exit
The L,C,R fronts shold have the tweeters about ear height in the seated position. I have read the same thing about the rear speakers being higher and I have got mine at about 6 feet on the wall. Maybe stands for the rear speakers are not made. It might be stands are unstabe at that height. If you can not find rear stands, you night be able to get boxes to set the 2.5' stands on to get more height. Maybe wood boxes. Just a thought.
skads_187
skads_187
I just found out, I believe the sp-25i is 25 inches. which is even less than 2.5 feet. I think I might take your advice and put a box. just gotta make it look nice now.
