I have a pair of psb image 5T towers, one is fine and one sounds "off". I have narrowed the problem down to my right speaker by changing amplifier channels/speaker wires and rca's. All the drivers are functional, I can hear them each working with my ear right next to them. So the problem must be the crossover? The tower sounds like the tweeter isnt working and it's wired backwards(confused)
My question is if the tweeter could be blown or damaged but still work slightly?
I am currently trying to find more image speakers for spare parts to further narrow the issue. They sound fantastic even in their damaged state, so I am anxious to hear them working correctly.
System is:
Pioneer Elite vsx 82txs
Kenwood km-x1
Kenwood basic m1
Psb image 9C
Psb image 5T
PlayStation 4
NEC projector
I'm sure that the tweeter is supposed to be in reverse polarity. That often has to be done to prevent a null at crossover.
Yes, a speaker can, and often does, loose output. What happens is that over driving the speakers causes heating of the VC and leads to break down of the enamel insulation of the VC coil. So shorts develop between the turns. This lowers output and impedance which can damage amps and receivers.
The way to test this is to take the wires off both tweeters and measure the DC resistance of both with an ohm meter. If the tweeter from the bad speaker shows less DC resistance than the other then that is your problem.
If both tweeters measure the same then the problem is in the crossover. This will almost certainly be a failing cap if this is the problem, although it could be an L-pad resistor.
Measure the resistors in the tweeter L-pad circuit and if they are OK then replace the caps in the high pass circuit to the tweeter.
This is something you should easily be able to trouble shoot and fix yourself.
If it needs a new tweeter and it is NLA, then check and see if there is a VC/diaphragm kit available. If neither are available you have a significant problem.
I see those speakers are around the 20 year old mark, so there may be a problem if the tweeter is no good. This may be part of the problem. Unfortunately Ferro-fluid which is placed in the VC gap of tweeters starting about 30 years or so ago to help cooling and prevent VC over heating is now causing trouble.
We are finding that the ferro fluid is now starting to dry up and not effectively conducting heat from VC to pole piece. This is causing failures. I recently had a Dynaudio D 21 AF fail after 30 years from this very problem.
