mediafrk
Can anyone out there recommend a HD front projection TV(LCD or DLP) for under $2000.
Thanks for any advice available.
U
Unregistered
Guest
Hi
For front projector there is nothing out there at the moment that is a better value than the Infocus 4805
www.infocus.com
Cheers
U
Unregistered
Guest
Sanyo Z1 and one of the lower BenQ models seem to get reviews and have alot of fans on various forums.
U
Unregistered
Guest
build your own for around 500$ :):) I've seen some highquality ones, and they don't take too long to build. guides are available if you need them to.
