Hi all, I am having problems, let me decribe and hopefully you all will have some insight. This receiver is part of a new HT setup which includes the receiver, TV, DVD player and cable box. All components are HDMI. I have both the DVD and cable box going to the receiver, and then 1 HDMI cable from there to the TV.
The problem that I am having is that very frequently when watching cable the picture and sound will freeze, sometimes with snow and some ghosting, but mostly just to a black screen. Turning the receiver on and off a few times will fix it. This does not happen when watching DVD's. Plugging the cable box into the TV using HDMI also solves trhe problem, so the receiver seems to be the root of it, but again, is fine with DVD's. Occasionally the screen will go green, and sometimes a message come up telling me that I am watching unautorized HD content and that HD playback will be disabled. The only HD cvontent on my whole system is from the cable box, so there should be no copyright issues. Any ideas? Is it a setup issue, or a bad unit? If bad, any idea why the DVD player works with it just fine? Thanks in advance.
-Justin
