The multi channel mode on my HK is called 6/8 channel direct. i've been trying to get the sound there, not the normal dvd setting, which uses my digital coax connection.
HK says all i need to do is use the 6/8 Channel Direct to get it working on the receiver end. I can't see anywhere in my DVD manual that states how to change which audio output to use. Right now i've got HDMI running to my tv, coax digital to my DVD input on the HK, and the 6 analogs going to my 6/8 Channel Direct input on my HK.
I also have tried setting it to multi channel, 2 channel stereo, pcm, bitstream without any real luck.
My DVD player is capable us sending a digital DVD audio signal if you are only running 2 channel stereo. Obviously i want the multi-channel with the analogs, but no such luck yet.
funfunfun
