.....but....you can't bi-amp, unless you bi-wire from two amp sections....and doing such allows the speaker elements to not be paralleled, and remain at the ohmage they were designed to function at....when you use the bi-ampable/bi-wireable speaker paralleling the terminal posts plus-to-plus, and minus-to-minus, and only use one run of two-sided speaker wire coming from one amp section, you're actually paralleling two crossovers inside the speaker enclosure and the elements that are connected to the two crossovers....this changes the ohmage and the voice of the elements, does it not?....I say try both methods, Jamil, and let your ears decide.....
