Bevan
What happens if you plug a cd player strait into a power amp?
I'm guessing volume will be really low. I'm a bit afraid to try it though.
If the pre-out signal that goes from pre-amp to power amp is a higher level signal than that which goes from cdp to pre-amp, what happens if you connect the pre-amp out from one amp into a line-in on another pre amp? I would think that the signal might then be too strong?
Can I connect the front channel pre-outs on an av receiver to one of the line-ins on an integrated amp? I want to integrate my integrated amp into an HT setup, using only the integrated to play cd's, and using it to drive the front speakers when listening to 5.1.
the 2 channel integrated doesnt have a 'unity gain', and I'm hoping I can attach the av receivers out to one of the integrateds line-ins rather than have to disconect the integrated amps pre from it power and plug the av outs to the integrated power section, which would mean physically changing cables each time as opposed to just switching sources on the integrated.
is the tape-in better suited to what i'm guessing is a high level signal?
thanks for any help
b
thanks for any help
b
