Effects of plugging in to the back of the receiver
Now, it's my turn to ask questions.
1) What do you think is done to the electricity coming out of these sockets and where do you think it comes from?
Since I don't think the engineers are asleep at the designing board, I guess the plugs are literally an extension of the lines coming in, so I suppose it's not that bad.
2) What do you think it "degrades" the electricity from these as opposed to the wall socket?
If I plug a "noisy" device into the receiver directly that draws say, 1 amp average, then the resulting magnetic field will induce all kinds of currents inside the receiver. Worst case, let's assume that for some crazy reason, the load is pushing 240 hz noise directly back out of its power cord. You might then end up actually hearing this coming out of the speakers. I forget most of my electricity and magnetism but I seem to remember that magnetic fields fall off as something like distance cubed. Thus it would be worse than if the power cords were separated by some distance. Although, I suppose you might get a similar effect even if the noisy device was plugged directly into the wall.
3) What kind of load do you think these ancillary devices draw, anyway? It's not a power amp, which is a different animal entirely.
Conclusion: As long as you don't plug in a unit which draws more current than these can supply, the electricity coming out of these is just as good as the electricity going into the receiver.[/QUOTE]
Basically, I was thinking more in terms of the impact on the receiver, not the impact on the ancillary device you have plugged in. Presumably, the piggyback device's own power supply will filter the line anyways.
Maybe I'll try plugging some stuff in back there to see if anything happens...
